FPR and BOV shared boost/vacuum reference line
Old Jan 23, 2024 | 01:51 PM
fusion_ta66's Avatar
Default FPR and BOV shared boost/vacuum reference line
Any issue having my BOV share a boost/vacuum reference line with the FPR? I would be using a nipple on the intake manifold. Also, is smaller line better than larger? Any ideal size?
Old Jan 23, 2024 | 02:34 PM
Rainz/28's Avatar
I ran my BOV, hobbs switch, and gauge off a vacuum reference box tapped into the line behind the intake. Only my wastegate has a a dedicated line. I did about 15 searches on here when I was doing mine, and it had lots of walkthroughs.
Old Jan 24, 2024 | 01:58 AM
pdxmotorhead's Avatar
Porsche uses some popcan sized vacuum reservoirs to handle shared lines.... They are not real expensive , I have 2 on my 03 911 Carerra... (Just to maybe find them i a yard... or nline)
Old Jan 24, 2024 | 10:41 AM
Black_Sunshine_99's Avatar
I'm using the UPR six port distribution block on my turbo car.
The wastegates and FPR have their own dedicated line for boost/fuel control accuracy but everything else is plumbed into the distribution block.
Old Jan 24, 2024 | 05:34 PM
Thanks everyone. I have all my other lines figured out.
If I can have the BOV and FPR come off the same 3/8" nipple on the manifold I'm all set. I would have a Y tee right at the manifold and run 2 lines, one to the FPR and one to the BOV. But I'm slightly concerned that there might be fluctuations due to the BOV. But perhaps I'm overthinking it.
Old Jan 25, 2024 | 07:24 AM
LSswap's Avatar
I don't se any problems with a 3/8 manifold nipple followed by a Y to the BOV and FPR. Been doing that for years.
