STS People??
Old Jul 26, 2004 | 07:26 PM
Green Thunder's Avatar
Default STS People??
Can someone explain how STS's oiling system works?
From whayt I have read and see on their website, they are using the engines oil pressure to supply the turbo, this I understand! My question is the return side... It appears they are using a pump to return the oil back to the engine, the question is why is there a pressure switch mounted after the pump where it is just returning the oil to the engine? Where does a guy get a pump like that? Also their FAQ's state the system keeps oil to the turbo prior to starting the vehicle.. HOW?
Thanks for any info!
Old Jul 26, 2004 | 09:11 PM
CHRISPY's Avatar
Probably a check valve I am guessing
Old Jul 27, 2004 | 12:08 AM
TurboLT1's Avatar
Tenured Member
https://ls1tech.com/forums/showthrea...=193891&page=2
