More knock
Old Jul 10, 2024 | 03:20 PM
Gav's Avatar
Gav
Tune and last log attached. Tube is altered after that log
Regards
Gav
File Type: efi
File Type: ctz
Old Jul 13, 2024 | 12:12 PM
GMCGreg's Avatar
Due to a lack of computer skills I'm unable to look at those . Are you getting anywhere with the tune ? Removing a degree at a time from areas in the timing table that correspond with the areas where you are seeing KR ?
Old Aug 4, 2024 | 08:24 AM
Gav's Avatar
Gav
Cyl 8
Cyl 8
Old Aug 4, 2024 | 08:26 AM
Gav's Avatar
Gav
Cyl 6
Old Aug 4, 2024 | 08:28 AM
Gav's Avatar
Gav
C
yl 4
Old Aug 4, 2024 | 08:30 AM
Gav's Avatar
Gav
Cyl
Cyl 2
Old Aug 4, 2024 | 08:34 AM
Gav's Avatar
Gav
Plugs 8 6 4 2
Old Aug 5, 2024 | 10:15 AM
Gav's Avatar
Gav
Hi,
could this be causing my knock? Pre ignition?
best way to clear it if so?
regards
gav
Old Aug 5, 2024 | 01:31 PM
Black_Sunshine_99's Avatar
Old timer mechanics used to very carefully pour water into the carburetor of a running engine to break up carbon in the combustion chamber.
Not sure how much I trust this but could be easily done with a spray water bottle.
Old Aug 5, 2024 | 01:52 PM
Gav's Avatar
Gav
Haha, just reading loads on that, spraying into throttle body slowly with just boiled water.
think my piston are bad?
Old Aug 5, 2024 | 02:06 PM
It looks like carbon?
You have a before picture, try the water and see if it gets better?
