Need more fuel suggestions.
Old Jul 27, 2004 | 02:23 PM
buschman's Avatar
Default Need more fuel suggestions.
I'd appreciate any of you fuel gurus to check out this thread and add your two cents.
https://ls1tech.com/forums/showthrea...27#post1592527
Thanks,
Mike
Old Jul 27, 2004 | 03:37 PM
Inspector12's Avatar
TT-TECH Veteran
I would slap a MSD boosta pump on that 340 of yours and see where that gets you MTI has used that set up on a customer car to put down over 700 to the wheels. Oh but did I mention that was on the stock pump. Just a thought and it is fairly cheap at $225. I am using one on my car and it works good. It should be even better with the Walbro you have etc...
Old Jul 27, 2004 | 04:56 PM
2001WS6Vert's Avatar
Dual intank, Hobbs switch, #8, #6 teflon feed & return, billet rails, boost reference regulator, problem solved and you can move onto bigger and better things. It'll also be as quiet as stock.
