Non-Resistor vs Resistor plugs
I also have run since day 1, R5724-8 race plugs. Non-resistor. Baffles me why in today's age NGK doesn't make this in a resistor version. But they don't.
I'll also say that I run stock AC plug wires (780 ohm) and still use the stock metal boots. My car has backwards stock manifolds, so I can do that.
Last week I decided the try resistor plugs. I chose a BKR7E. 7 heat range, 5k resistor. It's a gasketed plug but fits the LS just fine.
Not really meant for tight gap (.018") so I modified the ground straps slightly.
Both of these plugs are slightly extended tip.
Made some passes at the track leaving in 2nd. Mid nines at 150. 21 psi on a ramp.
Absolutely no change in my HPT data logs. Same glitches etc.
So it's not the plugs!
I have a Holley Dominator system I got for a deal from a buddy waiting in the wings for next year. Problem solved. I'm sure its fine with non resistor plugs.
Ron
My easy solution for high RPM LS operation is to fit an over-sized ( Larger diameter) Alternator Pulley.
Slowing down the alternator shaft speed also reduces wasted inertia, belt slip, and alternator will last longer.
Stock ( L8292) 145 amp truck alternator works great at reduced RPM, I have a 3 inch pulley on mine, and it makes 110 amps at hot idle ( engine 750 RPM )
On a different platform, ( first gen 350 CID) Ice race car sustained 4500 to 6500 rpm for long periods, I ran a 4.5 inch deep V-Groove alternator pulley to keep rotor speed down.
