Procharger Bracket w/HD Tensioner
Old Nov 14, 2024 | 12:59 PM
No Juice's Avatar
Default Procharger Bracket w/HD Tensioner
Who here is running the new f-body Procharger bracket w/HD tensioner? Does the idler clear the sway bar ?
Post any installed pics you may have
thanks
Old Nov 14, 2024 | 04:31 PM
No Juice's Avatar
@Bob@BruteSpeed
Is this the correct idler pulley? I thought the pulleys were supposed to matched. This one is larger and has shoulders on it
Old Feb 28, 2025 | 11:22 AM
ws6-formula's Avatar
Did you ever figure this out? I am running that bracket and all my stuff clears the sway bar and its a 10 rib set up. PM me your cell number and I can text you some pictures if you haven't made any headway. Also from MN
Old Feb 28, 2025 | 11:56 AM
No Juice's Avatar
Yeah two of the three positions worked. All working good
Old Mar 23, 2025 | 03:06 PM
99bluefirebird's Avatar
What blowers will the new bracket clear? And what 10 rib crank pulley did you go with?
Old Mar 26, 2025 | 11:01 AM
No Juice's Avatar
IT will hold the F-1's. I don't have a 10-rib just the 8
