procharger crank pulley
Old Dec 20, 2024 | 06:41 PM
IMPALAMAN1's Avatar
Default procharger crank pulley
12 rib pulley is set back more than the idler pulley and blower pulley. Any one have a favorite shim kit?
Old Dec 21, 2024 | 12:12 PM
IMPALAMAN1's Avatar
Apparently i'm the only one. I ordered the Jegs shim kit. Ill report back if it work.
Old Jan 7, 2025 | 02:36 PM
IMPALAMAN1's Avatar
Got the kit. I needed all 3 spacers, I had to drill 3 holes to clear the AC pulley bolts. It could use a little bit more but I think it is close enough to not eat up belts. I did need to order longer bolts. 3/8-18 X 1.5.
