Another turbine wheel size question....
One more thing, for 1:1 backpressure to boost, using the best cam for an NA version of the engine will be best for power. Once you start getting into 2:1 you probably want less camshaft overlap. Maybe even a little negative overlap. I can't tell you the exact crossover points though. I can say Sloppy Stage 2 cam has 5 degrees overlap I believe and works fine with your typical 5.3/6.0 with 7875 turbo everybody has, its been done literally thousands of times. A turbo specific cam with slightly less overlap won't hurt though, might help depending on your combo. A cam with 30 degrees overlap will probably kinda suck to drive on and may hurt power.
I know I spoke in generalities but hope this helps!
PS: I'm a big fan of stock type long runner intake manifolds. In my humble opinion its not optimal for your typical 6000rpm street turbo to run a short runner manifold. Its going to hurt low end torque and cause it to spool later. Now if you are going over 7000rpm with a high stall converter then it makes more sense. I DO like aluminum intakes for durability reasons but a stock LS6 will take you really far.
PPS: that 6000rpm guy might find he likes something like the Truck Norris cam too. No cam is the best all around though, some are better than others but they are all a compromise.
