LS 5.3 turbo header log O2s placement.
Old Apr 2, 2025 | 02:37 PM
pegdmg's Avatar
Default LS 5.3 turbo header log O2s placement.
I am running a single 7875 Turbo on my 5.3, I ran a turbo log setup on the passenger's side. To get it to run in closed loop I need to run both upstream O2s correct? I guess my question is that will be an incorrect reading on bank number two correct? If I am running a wide ban 02s in the down pipe why are the up streams needed? I am new to the turbo world so please be easy on me. (Set up Is a 2003 5.3, gm pcm, 4l60e, 7875 single turbo)
Old Apr 2, 2025 | 11:51 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
In your file you could just change the injector bank selector parameter to the same side for all of them and use 1 o2 sensor for closed loop fueling. Definitely not ideal, but should work.
Old Apr 3, 2025 | 09:21 AM
91 Z28's Avatar
Disable the upstream o2 sensors and only use the wideband in the downpipe for closed loop
Old Apr 3, 2025 | 12:19 PM
pegdmg's Avatar
Thank You!
