Cutout affect on ebc duty cycle
ls1 gt45 turbo low boost,restrictive exhaust. So i installed a 3” cutout post turbo vacuum boost operated. I did have my spool settings 100% pre cutout with no spikes.
now getting boost spike so dropped to 0% for now, but may have to increase duty cycle to get same amount of boost i had pre cutout. Does that seem normal? Probably making sane power at less boost? I suppose if i have to add more fuel when logging i will know?
regards
gav
Riding out the spike is half the fun! We use to port the turbos to bypass the WG and spike as high as possible!
regards
gav
It was a very large difference between open and closed performance wise, it was actually a bit rich on the AFR with it closed too.
https://youtu.be/-RqP52hZjfk
