found the problem but its very weird!! -- need some help
I think you have found your problem. The O2 sensor sees al that fresh air and tries to compensate by adding fuel like crazy. See what happens with the 02 sensors unplugged.
I tried calling, but the number i have is blocked by some pre paid calling card thing. Give me a call if you need.
I'll keep you guys posted and will let you know when it runs and makes some good numbers!
). So once I got everything out, I took the heat wrap off and no surprise -- couple spots where it looks like it is leaking/cracked/whatever. So its going to the shop tomorrow to get "patched up" and also to fix that downpipe a bit to make it work till I get my ypipe once it runs well enough to drive to the exhaust shop. Hopefully if all is well, and if this is the only problem, it will be running this weekend
Good news is that even though that bastard got super hot, nothing melted or fried!! Starter, plugwires, or the wiring harness runing down the side (allready heat shielded from header install LONG ago). Could be because of the way I have my plug wires routed (they basically lay on the motor mount area and come UP to the plugs -- coil packs relocated to the front of the car) oh and the heat shield **** on there (looks like it works!).
Everyone pray for me that this is the problem so I can get this beast on the road.
Then all I need to do is take the nose off and make some modifications to get some more air to that intercooler
I feel like an ***, this never happend on my car, i realy hope you or anyone else thinks i sold a junk kit. It was fine on my car till about 10-12 psi. i just couldnt get it tuned over 600 rwhp with 16+ psi so thats why i sold it.
I wish i could help more!!! Let me know, i think id try pulling the turbos, if it is the problem and turbo tech wont take car of it, I will pay to get them fixed, i feel bad this is happening. i thought the hardest part for you would be getting all the little stuff worked out, fittings, plug wires ect. Please let me know
I got the manifold back from my local shop today and it was cracked in a few places (one at the flange for the turbo) so I'm almost positive this is going to fix the problem. I got the manifold on the car tonight and threw a new set of plugs in it and then tomorrow after work I'm going to bolt the turbo and downpipe back up and let her rip. I also had the downpipe welded up where I made some cuts to get the cutouts off -- that way it will eliminate the 02 problem as well.
. And you are scheduled for a ride at Thunder if you make it down (although the car will be in street trim at that point).
Brandon
Jam, i like that idea!!! I had it wraped very well with buble wrap, but who knows. also it could be the hose running to the IC, that gets pretty sqashed down
