sts exhaust
Old Aug 5, 2004 | 07:38 PM
rozzyroz's Avatar
Default sts exhaust
i've ben doing some searching on the sts turbo system, and havent seen any alternate pics on exhaust exits besides the 2 in the center. i have a 99 trans am, and if i was to go with a system like this, i would want the exhaust to exit in both stock locations.
has anyone done a workaround for the intake pipe and exhaust exit(s) to give it that stock look?
the kit looks like it would make my car pretty fun at a reasonable price.
Old Aug 5, 2004 | 07:59 PM
SSnakekiller's Avatar
Well, you would have to have an exhaust shop fabricate the piping for you. We do not currently offer anything like you say, but I will put in the suggestion to STS.
Its really not a bad idea and could be done!
If you are interested in a kit, check us out!
Old Aug 5, 2004 | 08:40 PM
rozzyroz's Avatar
i have been really looking into this system for a while now. i just want a street car that is a fun to drive. the sts system seems to fit the bill....now to just wait on my investment to gain some lost money back damn stocks.
if i go with the sts kit (more like when), i'll put the exhaust on there like i was talking about. it would just be nice to see some pics to get a few idea's. prolly just a y pipe after the turbo would be the best bet.
Old Aug 5, 2004 | 10:44 PM
BlackCamaroSS02's Avatar
Its really fun to drive...it dominates
Old Aug 6, 2004 | 12:32 AM
Blackbird's Avatar
stay tuned, I will be doing exactly what you describe.
Old Aug 6, 2004 | 06:26 AM
rozzyroz's Avatar
awsome, that should help me out. be sure to post lots of pics
Old Aug 6, 2004 | 06:43 AM
ls1hybrid's Avatar
nice wheels
Old Aug 6, 2004 | 07:28 AM
slyws6's Avatar
I'm building my own kit that is similar to the STS kit and will be putting it on next sunday (just got the new shortblock in last night). Having a shop here custom fabricate all of the exhaust and ducting, I plan to run a dummy tip on the passenger side, I wouldn't recommend running a real tip because of the heat issue with it being next to the intake pipe.
-Sly
 Michael S. Palmer
Old Aug 6, 2004 | 12:22 PM
Jeepoo's Avatar
Default Exhaust
I have had my kit installed for about a month and a half. My exhaust looks just like stock. From the rear of the car the right pipe is your actual exhaust and we installed a chrome tip. The drivers side also has the same chrome tip and it is piped from the waste gate exhaust. The waste gate exhaust is only about 1.25 " so we made up an adaptor and then necked the pipe up from that to 3" to the tip. From the back or even the side of the car it looks like true dual exhaust.
On a side note, even though we havent dynoed yet, hopefully next week, we did some short bursts with the HP Tuner software connected, we showed no knock, although I am very careful for now to do only short bursts until we can confirm AFR when on the Dyno.
The turbo is surprisingly responsive and we see almost 6 PSI of boost.
I've had a couple of short races with a '03 Viper and a new ZO6. The viper
could not pull on me in 2nd. gear. The Corvette in a 4th. gear blast was losing ground.
Since the boost starts coming on around 2500 and is full in at 3000 lag is not an issue particularly because its a 6 SP. For Auto guys I would recommend a 3000 stall converter.
Hopefully I can post dyno sheets next week.
On another post someone had asked about theft of the turbo. It definitely wouldn't be hard. It takes about 20 mins. to remove the unit. A thief could probably do it in about 10 mins. Cut hoses,undo clamps and undo 4 bolts from
the exhaust housing.
Armin
Old Aug 6, 2004 | 01:40 PM
Blackbird's Avatar
good stuff jeepo.
sounds similar to what I am going to do except my tips are muffled tips (Supertrapps)
I also plan to plumb the watesgate into the exhaust path. what did you use to make your flange with to mount the pipe you made from your exhaust tip to the wastegate?
which turbo and exhaust housing are you using?
Old Aug 6, 2004 | 02:31 PM
Jeepoo's Avatar
Hi Blackbird
For the flange I used a piece of 3/8 flat steel which I shaped to the Wastegate outlet. The 1.25 pipe needs to get bent so that it points to the middle of your bumper cutouts,then you need to get an expanded apaptor
to go from the 1.25 pipe to the size of whatever tip you'll be using. All material for the piping and bending the pipe can be done at a good muffler shop. I've got pictures but since I'm kinda computer unfriendly, I don't know how to post them.
Armin
Old Aug 6, 2004 | 02:55 PM
rozzyroz's Avatar
has anyone thought of wrapping the pipes in thermal tape?
i would think that if i wrapped the intake and drivgerside exhaust it would help alot to keep a cool air charge. ill have to do some more thinking on this one
Old Aug 6, 2004 | 02:57 PM
rozzyroz's Avatar
Originally Posted by ls1hybrid
nice wheels
thanks bro they are a bitch to keep clean, but i loved the look, and had to have em.
Old Aug 6, 2004 | 03:18 PM
Blackbird's Avatar
jeepo if you can, email them to me, I would love to see them.
I can even host them for you so others can see too.
my email is heath@abbate.org
Old Aug 6, 2004 | 04:22 PM
bcs's Avatar
bcs
So did you same any money building it ?
