Fm13 And D1sc
Old Aug 10, 2004 | 09:14 AM
777's Avatar
777
Default Fm13 And D1sc
is the fms fm13 cam alright to use with an 8psi d1sc...if not what kind of cam should i get that is around the same size?
Old Aug 10, 2004 | 12:12 PM
CHRISPY's Avatar
what are the specs?
Old Aug 10, 2004 | 01:27 PM
777's Avatar
777
230/232 .591/.585 112 or 114
I think what i would try to do is end up putting the d1 on the engine while i wait for a 408 iron block to be built (is this ok...it is a full bolt on, pp stage 2 ls6 heads/fm13 cam)..how much power if it is possible would i be able to get with the d1 and my current setup?...i really want around 700-800rwhp and low 10 sec et's on pump gas w/ the new engine when its all said and done...i may end up having to go to an f1-r and fmic but i shall see...drive:
