Which ATI damper ?
Old Aug 17, 2004 | 07:44 PM
Fierce-LS1's Avatar
Default Which ATI damper ?
Guys .. which ATI damper do I order for my procharger
http://www.thunderracing.com/catalog...mid=16&sid=250
Is it the 105-917276 ?
thanks
Old Aug 18, 2004 | 12:09 AM
kp's Avatar
kp
If you are using the stock ATI crank pulley you cant use the ATI damper with it. If you have the ATI 8 rib setup then that part number (or the non underdrive) should be OK. Best call ATI (procharger) and see what they recommend if you have their 8 rib.
Old Aug 18, 2004 | 12:12 AM
Fierce-LS1's Avatar
I'm getting the SDCE 8 rib kit. Thanks for the input
Old Aug 18, 2004 | 12:14 AM
kp's Avatar
kp
I believe thats the damper they were selling with their kit so you will be OK.
