AutoTap Dyno Numbers...
Old Aug 18, 2004 | 08:51 PM
slyws6's Avatar
Default AutoTap Dyno Numbers...
Well some of you have seen my setup I just recently put on, similar to the STS kit. Anyway I got on it a little today, only took it up to 4400rpm's, I know this is no real dyno but I have found that it was within 10rwhp of my previous setup so it seems pretty accurate. Anyway this is with the wastegate set for 7lb's, not sure if I hit it because I was busy watching fuel and such, anyway I can't wait until I get my fuel system on and can take it up higher, then turn the boost up to 20 with the alky kit after lots of fine tuning tho.
-Sly
Peaks at 4400rpms were 435rwhp 511rwtq
Old Aug 19, 2004 | 07:30 PM
black_yukon's Avatar
It that an add on program from ATAP? How do I get it
Old Aug 21, 2004 | 09:49 AM
red ws6 99's Avatar
-Sly
Unfortunetly the numbers autotap spits out are bogus as seen from the exact same curve for hp and torque just with an offset.
Gary
Old Aug 21, 2004 | 10:17 AM
slyws6's Avatar
how can you be so sure since I only took it up to 4400rpm's. The haven't had a chance for a variance, and the car is not NA so the curves will be totally different. I know it doesn't mean much, just found it interesting. With my old H/C setup Autotap overshot the peak HP by 10 and undershot the torque by about 40. It's not dead on or anything just found it interesting. I would however like to see how accurate it is on a boosted car , after I get dyno numbers I'll post them and map the same dyno run through this program to see how they compare.
-Sly
