I regret getting this FMIC...
Old Aug 21, 2004 | 01:15 PM
frcefed98's Avatar
Default I regret getting this FMIC...
**** I regret getting this FMIC so late in the game lol.
Last night I took her out to the track and was able to get a pass in before the big event today.
Track wasn't hooking for nothing....like always But it was a cool 69 deg's I did a decent burnout to try to get the tires to hook and bam
http://home.comcast.net/~jsbird1998/fmic.mov
3.7megs about 1min on cable..
The DA was better this night than two weeks ago and my car shifted awesome down the track, and had a nice clean run and kept it floored all the way through the traps. I didn't expect this type of mph, the run would have been better if I 60'ed in the 1.6range like I normally do, but what can you do. I am stoked. I need to get some 60lb injectors as these 42.5s aren't cutting it now, a/f chart is rising at the end of the run. Boost was a just past 15psi, no slip SDCE
The car use to trap in the 116-7mph range before the FMIC. Two weeks ago with the FMIC the car went
11.46@113mph - botched shifts and lifting before the traps
60ft was 1.66
1/8t was 7.300
DA was worse at 8229ft
So if I just would have had the 60ft of two weeks ago, the car would have gone real close to its goal.
My quest for 10's continues, I need to get 60's, clean up the tune a little and hook up and I will be there:fingerscrossed:
Not bad for a IC change, especially with my cheap ghetto no name brand low brow FMIC lol, too bad it doesnt have a widely recognized brand name
Old Aug 21, 2004 | 01:50 PM
OSR 1's Avatar
Hey, its noyzee on Kens name, (stupid computers.
Congrats man, that thing is moving!!!! 10's with a good 60' are in the bag!
good luck
Old Aug 21, 2004 | 02:41 PM
frcefed98's Avatar
Thanks Noyzee Or is it really Ken...yeah right those ESP guys don't want anything to do with me anymore j/k Just got to get the hook and some bigger injectors now
J
Old Aug 21, 2004 | 03:16 PM
-=Merlin=-'s Avatar
Congrats Jer!
The mph is definitely there!
Are you going to compete today?
Scott and I will be heading out there in the afternoon.
Old Aug 21, 2004 | 03:22 PM
NA$TY-TA's Avatar
Thats awsome man................. How much the elivation and DA effect you up there??? Does it effect MPH also???? WE ran almost identical MPH.... my first tiem to the track and my only pass with the SDCE kit 124.19MPH. I cant wait till my IC goes on....... Hopefully around the first. Im sending you a PM.
Kyle
Old Aug 21, 2004 | 03:40 PM
-=Merlin=-'s Avatar
were are usually down 60-80hp from you sea level guys.
Bone stock we usually trap 98-100mph
haha, I see you live, literally, right by the sea
Old Aug 21, 2004 | 03:58 PM
NA$TY-TA's Avatar
Yep..... i can look out the window right now and see the ocean.... But its humid as hell here....... I keep seeing the awsome things Jeremy's doing and it makes me think..... what will i MPH when my FMIC goes on and i switch from the 3.7" blower pulley on there now to the same one hes running...... we run about the same MPH now......cant wait till mines on..... Good work Jer. Whats you FP look like at WOT??? What pump again and whats your base FP?? You using boost ref??
Later
Kyle
Old Aug 21, 2004 | 04:43 PM
frcefed98's Avatar
Thanks Frank, Me and Josh will be heading out hopefully later, but I don't have $$ to run the car in the event, just to watch. I'll see you out there.
I was always under the impression that we are usually 80-90 hp down. We make about 82 percent of the power that we should be making at sea level.....losing about 18% total, those numbers always run about the same as my dyno corrections...my 2 pennies. Our elevation kills us big time, the DA doesn't help either. A lot of people don't believe that our cars lose that much power up here. Only thing I can tell em is bring their car up here and lose to me
FP is at 58 psi, pump is a Racetronix plug and play unit. No boost reference as I had to do some tuning on my own. I now have a closed loop tune at PT and at WOT it goes open loop and adds fuel like it should. On my efilive logs on the highway going down there my injector dc's were at 105% at 5600 rpm and 122% at 6100rpm They are getting worked pretty hard. When I had it boost referenced, my IFR tables and 1:1 rate weren't jiving as soon I got into the gas, my afr would dip to 10.1 pretty quick. I'm new to using LS1edit, but kinda had to do something as my luck appearently ran out with the tuner that was doing it before??
 Michael S. Palmer
Old Aug 21, 2004 | 08:34 PM
Black Blown 02's Avatar
12 Second Truck Club
Very nice! That's a huge mph gain! I'm going to the track friday for my intercooler results.
Old Aug 21, 2004 | 10:20 PM
Eric Bazan's Avatar
WOOO HOOO!!!!! You're flyin'! How is that tune coming? Looks like your getting the hang of it. Put that rocket up on the converter and launch it! I wanna see a wheels up launch.
Laters lil' bro!
Eric
Old Aug 21, 2004 | 10:51 PM
frcefed98's Avatar
Thanks Black blown, I hope you see some good track times too.
Sup Bro, I tried to call you but no one answered. I stalled it pretty high on that pass but it spun em, no traction at all, but I drove her out of it instead of lifting and stomping like I normally do Sheeit, did you pay attention to the end of the video, I didn't let off until I was way past the lights on that run, I'm starting to get use to the car again lol.
J
Old Aug 22, 2004 | 08:27 AM
kp's Avatar
kp
You have the mph for 10s, you are going to need a better then 1.66 60' to get there though. 1.55-1.60 should get you there so work on them 60's
Congrats, thats doing very well at that elevation..
Old Aug 22, 2004 | 10:34 AM
frcefed98's Avatar
Thanks KP, I have to go to a more aggressive tire, like a ET Drag. Our track prep is non existant, and I had some good luck hitting 1.55-59's with ET Drags last season. Thats about the only way I'll get those 60's.
Old Aug 22, 2004 | 02:25 PM
NA$TY-TA's Avatar
You going o buy another set of rear rims so you dont have to drive around town on EY drags??????
Kyle
Old Aug 22, 2004 | 02:29 PM
frcefed98's Avatar
Nah, I'll just use em for track only and put the stock rims back on. Do the ol switch a roo for track time. Its a pain in the *** but I need to hook. I'll use the ET streets until they are worn down, so these have about 2 months left on em at the most before i'll be buying ET drags.
J
Old Aug 22, 2004 | 02:49 PM
Hershey Squirt's Avatar
Better save some for those 60s.
Old Aug 23, 2004 | 08:19 AM
Noyzee's Avatar
8 second mod
is this ken or brad now??? hehehehe
Tires tires tires!!!!! 1.5 or better and a little better track prep, 10's all day baby!!!
Old Aug 23, 2004 | 09:02 AM
kp's Avatar
kp
There is no comparison between ET drags and ET streets on a crap track - same day, same track: 10.5x27x15 ET streets @ 11psi 1.602 60' best and spinning pretty bad, 9x28x15 ET drags @ 14psi 1.474 60' best. On a well prepped track the same ET streets have gone 1.46x 60' but at the local tracks they just dont do it..
Old Aug 23, 2004 | 10:02 AM
Blackbird's Avatar
Damn you J!
I read the title this morning and my heart sank..... then I read the post
Wheeeeeeeeeeeeeew!
Old Aug 23, 2004 | 12:54 PM
NA$TY-TA's Avatar
Originally Posted by Blackbird
Damn you J!
Wheeeeeeeeeeeeeew!
Same here.....................
