Land and Sea Dyno Question
Anyway my car is a Incon TT setup with 9 psi of boost on 91 octane, low timing (15 deg a max power). Car is an A4 and ran a 12.6 at 111 mph in quarter last weekend at track altitude of 4200 ft.
Dyno was with the following conditions:
88 deg F, 45.6 humidity, Barometric pressure 26.4
According to the dyno my car made a whopping 300 lb/ft of torque at 3300 rpm then following off to about 200 lb/ft. Hp maxed out at 204 hp at 4600 rpm and then following off to 100 hp. These numbers are supposed to be corrected to "standard" conditions. Car never really loaded up and pulled way to fast. I did not get a chance to watch the boost and since I did not plan on running did not have my laptop logging the pcm or my in car wideband. The dynos wideband was showing 10.5:1 AFR, my car runs 11.5:1 down the track. So they were definetly not loading the car enough.
It was not just my car a stock a4 2000 corvette made 120 hp max and about the same torque. A supercharged viper (runs about the same ET as me but with 7-8 mph higher) had 535 hp but 280 lb/ft of torque - don't think so. The viper got like 4 runs because by this time they new they definetly had some problems, especially with computer controlled cars.
According to everything I have read the dyno has to be loaded more and more either by hand or with the computer until power drops off. They were not doing that and were just having us pull into we hit redline. All pulls were done with a 1:1 transmission ratio (3rd gear in my case).
Anyway I will be calling Land and Sea tomorrow, since the place could not answer any of my questions.
So questions is what did they screw up, I am assuming they just did not load the cars up enough so the crappy numbers?
I've heard a couple negative things about land and sea dyno(the brand) too. I pulled this off another site(diesel truck site) sounds like the same problem too, the dyno(land and sea) was new to the operator and they had to load it different ways to get decent numbers.Quote From the post:
Thanks JC
J
Just run up here to Albuquerque and have Chris dyno it on his dynojet. He is awesome at dynoing turbo cars so you should have good luck. Chance for a road trip too
J
I will be doing some tuning this week with 100 octane, some more timing and maybe a little more boost if thing go well. The car was running 116 mph in the quarter in january with the same tune (well I did fatten it up a little for the summer).
Gary
