Methanol or intercooler
Old Aug 30, 2004 | 04:04 PM
goober35's Avatar
Default Methanol or intercooler
Witch would be better a air/water air/air or methanol. On the street i would be at 5-6psi but on the strip i would crank the boost to 14-15psi. Witch would be safer on the motor. Also it will be 9.5CR on my DD.
Old Aug 30, 2004 | 04:20 PM
Wildman's Avatar
Alky/Meth... because you get the cooling effect AND raises the octane level, extra fuel to help prevent detonation.
JMO
Old Aug 30, 2004 | 04:24 PM
CAT3's Avatar
Restricted User
street and some strip use, I believe A/A and if you want the additional cooling/octane, add the meth later. But thats just from my research. I believe for the most part, A/W is best suited for more track, as you can use ice etc...
Old Aug 30, 2004 | 05:31 PM
Unusual T/A's Avatar
Why only 5-6 on the street with that compression ratio? I'm doing air/air and a meth kit later on.
Old Aug 30, 2004 | 08:09 PM
goober35's Avatar
SO if i do the air to water i dont have to have dryice and ice and water and alky in the tank at all times. I might run 6-7 but right now it is just a though.
