LS1 air consumptiom
Old Sep 1, 2004 | 10:49 AM
EightBall's Avatar
Default LS1 air consumptiom
Under 7 psi of boost, what does a 346 ci LS1 consume in terms of lbs/min? Ive gotten answers anywhere from 43 to 51 to 60. I need this info bad...
Old Sep 1, 2004 | 11:30 AM
MIGHTYMOUSE's Avatar
base airflow rate = (cid*rpm*.5*VE)/1728 = ___cfm
pressure ratio = PR = (14.7 + boost)/14.7
boosted airflow rate = PR*base airflow rate = ___cfm
cfm*.069 = #/min (standard)
finding your correct VE for your heads and FI set up is critical.. can range from .7 to 1.x... through my accel dfi calculations mine is right at .91 at that boost level.
CID = 346
PR at 7psi = 1.476
VE = .91
max rpm = 6500
this would give a #/minute for my set up of 874.17cfm * .069 = 60.31 #/min
at my current boost level of 17, my VE is .93 so my #/min is about 90
also.. if you know your compressor efficiency then muliply that by the ideal PR to get the real PR.. i didnt do this in my calculation because it is skewed by intercooling quite a bit.. and i have a really good intercooler.
Old Sep 1, 2004 | 11:43 AM
MECHAM's Avatar
http://www.forcedinductions.com/consumption346.htm
Old Sep 1, 2004 | 12:04 PM
Mark C's Avatar
That's an interesting table.
I see 53 at 8. I would have guessed 50 at 7 psi.
According to that table, its 5,900 rpm at 50, 7. Thats about where I stopped the dyno pull.
My actual numbers are very very close to that table.
Old Sep 1, 2004 | 12:44 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Keep in mind the table I made above is using a constant EV, which in the real world we know it will not hold true, but the #'s should be VERY close.
Jose
Old Sep 1, 2004 | 12:55 PM
EightBall's Avatar
that is the table I had been going off of, should this be a good general resource for a stock LS1 engine?
Old Sep 1, 2004 | 12:58 PM
LS1TECH Sponsor
Yes it will tell you what you need.
Jose
