Tuneing problem with STS
Old Sep 15, 2004 | 12:14 AM
y2khawk's Avatar
Have you done anything with the wiring to the pump?
I've personally run a single intank 255 past the 600 RWHP point, and done it on other cars as well. It sounds like the pump isn't seeing full voltage.
The 100% load/default thing raised the inexperienced tuner flag for me.
Just don't let him learn his way around Edit, but learning a hole in your pistons
Old Sep 15, 2004 | 12:20 AM
2ktransam's Avatar
I am runing the racetronix kit which has the wiring coming off of the battery that is supposed to supply full voltage to the pump. The thing that probably threw everybody for a loop on the tuning thing is probably my inexperience and not explaining the problem right.
Old Sep 15, 2004 | 06:40 AM
PurEvl's Avatar
I have a single intank with over 600rwhp so it can be done
Old Sep 15, 2004 | 11:01 AM
White_Hawk's Avatar
Have you changed your fuel filter recently? Are your injectors running static?
-Geoff
Old Sep 15, 2004 | 01:22 PM
ssblackss's Avatar
It sounds more like an injector issue than a pump issue
Stock Injectors? May want to up your injectors to flow more your pump is good for more than 500hp IMHO
Jonthan
Old Sep 15, 2004 | 01:48 PM
Wildman's Avatar
The Racetronix system should be good for ~700hp. It is a good setup.
And as Harlan said, we would hate for you to detonate a piston while he was learning.
Something is not right, you have the injectors and the pump to support what you are doing. Replaced the fuel filter?
Old Sep 15, 2004 | 02:39 PM
2ktransam's Avatar
Thanks for the help guys. I will try the fuel filter and see if that helps.
