heads/cam with 8 psi
Old Sep 17, 2004 | 09:01 PM
Blown Ta's Avatar
Default heads/cam with 8 psi
hi guys just a couple of quick ?'s
1. i got a good deal on stock 6.0 lt lq4 aluminum heads , would these be ok to run 8-9 psi on stock buttom end.
2. what cam do you guys recommend with these heads and 8-9 psi? i was thinking just a ls6 cam because i still have to worry about passing immisions.
cam specs would be great
3. would the ls1 valve covers fit the lq4 heads
4. what head gasket should i use.
thanks
Old Sep 17, 2004 | 09:13 PM
PurEvl's Avatar
umm I went 6psi 8 rib d1 with 6.0l patriot heads and a 230/234 cam and ended up around 587 and 519 tq @ 6000 rpms(out of fuel at the time)... that will kill your stock block bro
Old Sep 18, 2004 | 12:53 AM
mdhmi's Avatar
I'm with 5-liter-eater: you're not going to run nine pounds of boost plus a heads and cam package on a stock bottom-end for any significant period of time.
Mark
Old Sep 18, 2004 | 10:55 AM
Blown Ta's Avatar
ok, lets say i keep running on 6 psi, and bolt on those heads, what cam should i get
my goal is 500 rwhp
with 5-6 psi i got 430 rwhp
btw the 6.0 heads are stock they are not ported. but they do flow better then the ls1 heads
Old Sep 18, 2004 | 11:21 AM
NA$TY-TA's Avatar
Valve covers fit just the same as any other.......... The compression drop.... about 9.4-9.6:1 depending on headgasket choice will help....I love the 6.0L MLS head gaskets and there like $50...... but like everyone else is saying..... the bottom end wont last long.... A LS6 cam should pass emissions... i would think...... Its all about tuning... i cant stress that enough..... oh and you will be out of injector so go and ahead and get another set..... and 42#'s wont be big enough if you are going to be doing 8psi.......... it takes alot of $$$$ to make a FI LS1....
Kyle
