turbo vs gas mileage
Guys:
I have a question that someone can answer.I am planning to install a turbo kit to my 99 LS-1 T/A.I will be using 6.0liters heads to lower the compression to 9.1.I have talk to many people and they have told me that i would need to install 42# injectors to make this set up work by the way my goal is to acheive 500RWHP and around 550RWTQ.Using a t-63 or a T76 at 10 psi and a walhboro 255l.Here comes the question USING INJECTORS THAT BIG CAN I GET A DECENT GAS MILEAGE?by the way the car is a daily driver the extra power will be needed for some street racing.Can anyone share some light?
ANOTHER CONCERN WOULD BE FOR TUNNING.
My truck bone stock never got more than 16.5mpg. After a beefy cam (226/5.35/112) for a 5.3L, 42lb injectors, long tubes, no cats, intake etc. I was still getting 15mpg average. The tuning is key.
That being said, once you floor it with an FI car with that much HP your milage will take a huge dive and so repeatedly doing so on a single tank of gas will decimate you milage
I am getting about 20miles or more less by half a tank then before the turbo. Guys:
i usually got around 20mpg with beeting on it a bit.
when i was stock motor (10:1CR) with my T76 turbo kit my gas mpg dropped to 23mpg were stock it was consistant and 25mpg
so it seemed like dropping CR hurt the worst for gas milage, but i dont think 20mpg was bad for a 512rwhp car.
Personally, I'm not counting on ever seeing that +3 except on a trip -- I only found this out while sick and when I was having a slight problem and couldn't go to WOT
