Upgrades to make? psi to meet my goal?
Old Sep 27, 2004 | 09:55 AM
Ellis Juan's Avatar
Default Upgrades to make? psi to meet my goal?
Got the flow finally, now just have to find the time. full bolt on car .motor has 110k so im gonna drop it. Here is what im thinkn. Forged pistons that will give me around 8.5:1. upgraded rod bolts, have crank inspected,rods. D-1sc and fmic. injectors and fueling. 8 rip setup. lookin for traps around 130, what psi? and are these upgrades suitible or should i upgrade the rods?
Old Sep 29, 2004 | 12:23 PM
Ellis Juan's Avatar
anyone
Old Sep 29, 2004 | 12:53 PM
smokinHawk's Avatar
psi is useless,
HP goal.
how much do your car weigh.
should need about 600rwhp on a 3600lb car.
Old Sep 29, 2004 | 01:01 PM
Ellis Juan's Avatar
weight 3650, im shooting for 650-700. Im still not clear when fuel limitations come into affect. Im doing my research on what type of injectors to use etc. takes a while.
Old Sep 29, 2004 | 02:24 PM
CHRISPY's Avatar
If you are using the stock PCM go with the 72# units that Nogo has. Apparently they are easy to tune and work well. Dual 340 pumps (intank) and a 1:1 rising rate regulator and you should be good to go.
Old Sep 29, 2004 | 02:49 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
60lb Mototrons at least,
I would also do a cam,
and 600rwhp is very doable.
I would run ARP head studs too.
Old Sep 29, 2004 | 02:50 PM
Ellis Juan's Avatar
What about fuel rails and lines? I thought i saw something about 98s having decent rails. since ive posted this ive read a little on the d-1sc and the f1. what are your opinions.
Old Sep 29, 2004 | 03:32 PM
LS1Tech Co-Founder
I see people doing 600-650rwhp with stock rails and lines.
I have aftermarket rails, gas tank, braided fuel lines, and an external regulator.
