STS kit results
Old Oct 1, 2004 | 04:34 PM
No Juice's Avatar
Why are the low RPM #'s lower than stock. It looks like it has a 3300rpm lag
I thought these systems were to hit full boost by 2500rpm?
NOt bashing, just wondering. I am a FI newb
Old Oct 1, 2004 | 06:49 PM
SS00Blue's Avatar
Originally Posted by Slowhawk
9.2 at 156mph
That's BAD! Gotta vid and slip?
Old Oct 1, 2004 | 07:25 PM
PurEvl's Avatar
turbo needs to break in an loosen up, quite common
Old Oct 1, 2004 | 08:00 PM
CHRISPY's Avatar
Originally Posted by SS00Blue
What was the et/mph? I couldn't read it... Thanks!
SC-
LOL!! I have been asking the same thing about your posts for a year and a half
Old Oct 2, 2004 | 01:05 PM
Cld12pk2go's Avatar
The lower numbers would be due to the backpressure in the exhaust due to the turbo.
This is compensated by the boost produced from 3300 rpms and up.
It would seem that the STS kits have more lag comparied to typical kits with the same size turbos. Full boost wasn't reached until ~4200 rpms. I would expect a typical kit to have full boost with this turbo by ~3000 rpms.
I guess this is due to the lower exhaust temps being less capable of rapidly spooling the turbo.
But the kit does make good power, just with a narrower powerband.
Old Oct 2, 2004 | 04:13 PM
trtturbo's Avatar
My car makes full boost by 3100, not starting to make boost. Keep in mind, the dyno may not load the engine enough to represent how boost is made on the street. I have had my car on a "loose" dyno that did not load enough to show full boost.
Old Oct 2, 2004 | 10:23 PM
Slowhawk's Avatar
LS1Tech Sponsor
On the street the car gets full boost at 3000rpm.It starts to make boost at 1800 -2000rpm.
