STS turbo system question.
Old Oct 6, 2004 | 12:16 PM
red fury's Avatar
Default STS turbo system question.
I wounder If you can run that system if you are running a cam with longtubes....would you still get 4psi from it?
Old Oct 6, 2004 | 01:22 PM
Slowhawk's Avatar
LS1Tech Sponsor
Yes,if your ussing the manual boost controller.
Old Oct 7, 2004 | 01:41 AM
byarddog's Avatar
Default longtubes
I have slp long tube headders with 3 inch slp ypipe. I also have a 224 224 561. 112 cam with an ls6 manifold and I run 5 psi all the time. hope that helps
Old Oct 7, 2004 | 11:52 AM
SSnakekiller's Avatar
You mean will you still get 5psi from it? What are the specs of your cam? Lets see if it would be a good cam to use. Yes cam and longtubes are fine to use with the sts kit.
Old Oct 7, 2004 | 01:43 PM
red fury's Avatar
cam specs are....224/224 .561/.561 with 112 lsa
I have read and seen dyno results on stock cars adding about 90-100rwhp and 120rwtq......could I expect the same with the cam and longtube headers running 5psi and what about running 7psi with the methanol injection on the street? The methanol is activated via electronics?
Thanks for the responses
BYARDDOG have you dynoed your car running the kit yet? Iam very interested if your car is a M6!
Old Oct 7, 2004 | 02:58 PM
Your cam will work with the kit, as you really have no overlap which is good. Most car are putting out 420+RWHP at 5psi on stock motors (stock heads/cam). We have seen as much as 480RWHP at 6psi, stock motor.
Yes the methanol system is typically set up so that when you activate it, it sets the boost to high and arms. Then when it sees so much boost it sprays the meth/water. Very nice setup and cools down the intake a lot!
