Seeing 7lbsof boost from a 5lb sts kit
Bosch style wideband sensors (any WB actually), should be mounted AFTER the turbo. The backpressure created by the turbo will shift the wideband readings, normally richer than actual.
So for all you STS guys, unless you've got the wideband in the back of the car after the turbo your probably leaner than you think
Just a warning
Now on the STS trucks there is only about 12" of pipe coming off the turbo normally. Would'nt this pose a problem for the wideband to read properly? Im my case I have a total of about 3' of pipe before my muffler and can easily take my muffler on and off so would I still be able to weld a bung into the pipe and get a decent reading? Also if you get any kind of oil into the turbine due to leakage or anything how is that going to effect the wideband?
Just a warning
I've got one in each down pipe, only about 8" from the end. They read pretty well even at idle. Once i'm into the throttle even a little, they read just fine.
a little oil shouldn't hurt them too bad, coolant does more damage. Coating them with oil might give funny readings until them burn off the oil. But I don't think it'll kill them.
http://wbo2.com/lsu/
MECHAM, no not a good spot. If you can move it into the downpipe it'll work better. Doesn't seem like that's too far to move based on the pics.
The problem is turbos create alot of backpressure, normally 1.5 to 2 times manifold pressure. O2 sensors rely on a fresh air reference on one side of the sensing element, usually provided where the wires go into the sensor. That reference is at normal atmosphereic pressure, and the sensor acts on the sum of pressures for remains O2 in the exhaust stream. Raise the pressure in the exhaust too much and the curve of the sensor is way outta wack.
how much do u think my A/F is off by having it where it is located in the pic?
and where//how far do i put the wideband in the downpipe past the turbo??? (ideally)
sry to hijack yr thread blu-ss
Wolfee
try getting the signal from the manifold instead of the turbo.
this has fixed this issue for a few people. Cost ya about $5 in vacum line to try.
my kit came with a big 5/8th's, I think it is, plastic T to tap into the brakebooster line. I already had one due to my previous blower kits but the point is you should be able to get signal from there too.
may not fix it but it certainly will not hurt to try.
