STS FMIC Camaro SS Complete
Old Oct 9, 2004 | 10:32 PM
SSnakekiller's Avatar
Default FMIC STS Camaro SS Complete
Original Install:
IC Mounted
FULL PICTURE SET
Car will be seeing 10psi wastegated and 15+ with meth
btw, pressure drop seems to be a little over 1psi on the 5psi spring. I got a 12psi spring hoping that I will end up somewhere around 10 after the pressure drop. Havent put the spring in yet, but will post when I do. Under boost I am not seeing above 92 degrees and this is in south florida weather...bout 90 degrees ambient which pretty much says the IC is doing its job
Old Oct 9, 2004 | 10:46 PM
pdd's Avatar
pdd
wow! very nice
Old Oct 9, 2004 | 10:50 PM
NumberOneSled's Avatar
Hey Jesse, whens this thing going to the track?
Old Oct 9, 2004 | 11:00 PM
Blackbird's Avatar
move the wastegate signal from the turbo to from the manifold then it will know about the pressure drop accross the IC and you will get the boost the wastegate is set to.
Old Oct 9, 2004 | 11:06 PM
StoleIt's Avatar
NKAWTG...N
perty...one day my car will also have a FMIC...one day
Old Oct 9, 2004 | 11:19 PM
Blackbird's Avatar
nice job.
any noticeable delay in spooling with the fmic and extra piping?
I considered doing it similiar to you but chose to go for the shorter piping and the bonus of extra traction by relocating the battery. Pretty bold to weld everything. You're much braver than I.
Old Oct 10, 2004 | 03:29 AM
seal's Avatar
very nice
looks sweet!
that bumper is looking shiny
Old Oct 10, 2004 | 12:35 PM
sunsetSS's Avatar
Originally Posted by SSnakekiller
Original Install:
IC Mounted
FULL PICTURE SET
Looks Great where did you get that front grill, cut out like that!!? Never seen it before? How Much was it?
Old Oct 10, 2004 | 12:38 PM
StoleIt's Avatar
NKAWTG...N
qmp did that on their single turbo z28 as well. i think its just a regular slp grill with parts cut out. box cutter and exacto knife should do the trick.
Old Oct 10, 2004 | 01:18 PM
F8L Z71's Avatar
12 Second Truck Club
Looks sweet!
I relocated my vacumn line from the turbo to the manifold and my boost is more consistant now. It doesn't vary more than about 1psi whereas before it would vary as much as 3psi at high boost.
Old Oct 10, 2004 | 02:18 PM
NA$TY-TA's Avatar
Looks SWEET...... I like the Front Grill Cover...... Looks Awsome.....
Kyle
Old Oct 10, 2004 | 07:18 PM
I fabbed it...not something you can buy. If you want one similar let me know...
Old Oct 10, 2004 | 07:19 PM
btw thanks for the all feedback!
Old Oct 10, 2004 | 07:45 PM
GONEB4U's Avatar
SMOOOOOOOOOOOTH.
Old Oct 10, 2004 | 11:35 PM
LoneWolf28's Avatar
Looks clean! so do you guys think you'll be selling it as an upgrade for us STS guys?
Old Oct 11, 2004 | 10:24 AM
LS1mtZ's Avatar
Any chance of selling these? I'm lazy and i'm sure there are alot more people that would love to buy a FMIC kit instead of going through the cut and hope process.
Old Oct 11, 2004 | 10:51 AM
This upgrade is variable so let us know what you want and we will do it. Yes, we were thinking of offering a true bolt-on FMIC kit. Contact us if you are interested and let us know exactly what you want. It will be customized to suit your needs.
