Guys with 50mm Tial BOV, help please
Old Oct 11, 2004 | 02:49 AM
SuperSporttruck's Avatar
Default Guys with 50mm Tial BOV, help please
I was looking into getting the 50mm BOV and was curious what spring to use with it the 7, 9, or 11 psi. i know the decision is supposed to be based on motor vaccum, but just trying to get an idea, for a 6.0L with a cam and heads, thanks
Old Oct 11, 2004 | 07:56 AM
1point3liter's Avatar
LS1's should pull enough vacuum that the spring that comes with it should be fine.
When I used to play with rotaries I'd have to change the spring because they don't pull as much vacuum (especially when ported).
Old Oct 11, 2004 | 10:39 AM
That is what i am trying to figure out. It comes with any of them. Its an option, you pick when you order it. Anyone know ?
Old Oct 11, 2004 | 12:19 PM
NA$TY-TA's Avatar
I have the 11 psi spring in mine and i see 8" vacum at idle and around 9-11 cruising on the free way with my 4.03" over bore 6.0L...... so u should be fine.........
Kyle
