D1SC 8-12lbs
Old Oct 14, 2004 | 04:47 PM
1F8TL02WS6's Avatar
Default D1SC 8-12lbs
What would the best internals for this setup.
cam?
heads?
pistons?
rods/rockers, etc...?
What would you use, to build the best boosted motor to make it hold up for a long period of time.
Old Oct 14, 2004 | 07:15 PM
NA$TY-TA's Avatar
Give AP Engineering a call they will help you out with anything you can think of to amke a motor last on boost.
Kyle
Old Oct 14, 2004 | 10:38 PM
1F8TL02WS6's Avatar
haha Alrighty.
Old Oct 15, 2004 | 12:24 AM
mdhmi's Avatar
Are you staying with stock CI ? Is this for a race car or street car? Do you mind an aggressive cam? What type of budget are we talking about? Is this for a turbo or supercharger??
Mark
Old Oct 15, 2004 | 12:41 AM
BIGBOS's Avatar
I have a 6.0L iron block with a .30" bore, stock 5.7L crank, diamond pistons, eagle rods, the works.......TEA S2 5.7L heads......370c.i. 9:1 compression, if I had to do it over again, I would go 8:1 compression........still might in the future or if I go to freshen up the motor, don't think it will happen any time soon, Speed Inc. built it pretty solid.....
They are another sponser you should consider checking out.....
www.ls1speed.com
