Yet another cam question???
Old Oct 14, 2004 | 05:18 PM
Green Thunder's Avatar
Default Yet another cam question???
What is the consensus on this cam?
403 Stroker
8.4:1 compression
Turbo motor
Duration
234
230
Lift
591
544
on a 114
Thanks for any help!
Old Oct 14, 2004 | 05:20 PM
hellbents10's Avatar
LS1Tech Sponsor
The 114 is good, but whats the deal with these reverse splits on the turbo cars and trucks latly. Do they work really well?
Old Oct 14, 2004 | 06:16 PM
MIGHTYMOUSE's Avatar
anything will work awesome if you put a turbo in front of it.
im not a whiz on cams, but the reverse splits i have seen and like the one i run, do not have such a large lift difference as that.. maybe .580
also depends how efficient the turbo layout will be, what size turbo etc...
if you have a really restrictive set up you may want a straight up or even standard split cam.
Old Oct 14, 2004 | 06:24 PM
TA Dave's Avatar
I agree with that!
However a Boost engineer has advised me to go with a nice 6 to 8 degree split and to keep a close eye on the overlap...
He said a lot more too, but if I told everything I'd probably not get anymore info.
