Suddenly showing Knock...
Old Oct 19, 2004 | 03:55 PM
houseofboost's Avatar
Default Suddenly showing Knock...
My 383ci LT1 with YS-Trim blower is suddenly showing knock on the knock sensor deal. When I purchased the car, a few weeks ago, we drove the car in the heat and under boost it showed absolutely no knock. I got the car home the next day, approx. 20 degrees cooler, and the car shows knock with the same octane gas (114).
Have I bumped the sensitivity up on the knock sensor accidentally or is something wrong?
Thanks,
WB
Old Oct 20, 2004 | 09:43 AM
Got Me SOM's Avatar
no you might be leaner now that its cooler. try adding a little more fuel.
Old Oct 20, 2004 | 03:44 PM
tici's Avatar
Mhh... I have the same problem right now.
Is it possile, colder = lean?
Isn't the PCM using the IAT to compensate the fuel?
Or are SC engines too wild for a standard PCM?
Old Oct 20, 2004 | 05:22 PM
My car has the Fel-Pro/FAST system on it.
How does a guy have the car tuned if you live in Missouri...where its 50 degrees today and tomorrow it will probably be 70 degrees?
Old Oct 20, 2004 | 05:40 PM
Phate's Avatar
I was under the impression that a FAST system would automatically adjust the A/F between a small range if it had a WB sensor. Might want to look into that.
In the mean time...in order to be safe you need to tune it for the leanest conditions that it will see. Detonation will kill a motor a lot faster then too much fuel, as long as the rings are broken in.
Old Oct 20, 2004 | 05:57 PM
Thanks. I'm going to have it adjusted asap.
Gonna get it on the dyno in the next few weeks hopefully.
Old Oct 22, 2004 | 04:40 PM
jhelms's Avatar
Wes, good luck getting it on the dyno. Have you had any local races yet?
Oh yeah, if you have a chance to send those straps back we need to take one of Jimmy's cars to the track next weekend.
thanks,
Old Oct 22, 2004 | 04:50 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
colder = making more boost?
Old Oct 22, 2004 | 05:01 PM
tici's Avatar
No, colder = more air (denser air) = more oxygen for your engine, but the pressure gauge will show the same.
More oxygen = more fuel = more power
Old Oct 22, 2004 | 05:29 PM
LS1Tech Co-Founder
Wes, does your FAST have a w/b? Is it on?
