Belt shreading to pieces.
Cog drive huh....good luck I tried a cog set up but the belt wouldn't last past the tree before it was stripped of all its teeth....tried it loose, tried it tight the belt just wouldn't live. If you want cogs, I have a full set...100 bucks paid 500.
SDCE is your answer though, get with them, they will provide you a set up that will be able to handle the almight F1.
Hope this helps a lil.
J
Get the SDCE 8 rib tensioner
I have an F1 on my car, I'm running a 3.4" blower pulley, and a 7.25" crank pulley, 15psi at 6000rpms so far, should hit 16 hopefully, no slip at all
Should hit the dyno this week
As for the cogs, they are a 71T and a 31T the cog belt width is almost identical to the 8rib i'm running now....but I would stay away from them PERIOD.
Your cog set up might work really well, but the SDCE set ups work VERY VERY well, I'm seeing 15.5psi right now with no slip.
J
