installed ati, now car is overheating
Kyle
I will tell you this, you cannot wire the dual 11" setup directly to the stock relays, you will burn them up because of the amp draw, You need the realy kit that comes from SPAL so that the fans get power from the battery directly.
You will know you have the fans wired right by taking a piece of paper and placing it in front of the radiator. If the paper stays you have it right, check it on both sides of the radiator.
the wires for the hi/ low settings where joined together ( just like the ATI kit instructed)and then they split in to two for each fan. you might try that, or do it the right way ( and save the wiring harness from being hacked) by doing what bryan said
