SDCE alignment
Old Oct 28, 2004 | 08:09 PM
2000silverbullet's Avatar
Default SDCE alignment
Hey guys > I have attached a pic that shows how my alignment looks from under my car. The 90mm pulley is aligned in the center of the blower pulley and is not the same with the crank pulley, it is just a hair (or 2) to the left. The crank pulley and the blower pulley are near perfect from end to end. Should I shim the 90mm pulley? Does any one have pics or a discription of where their 90mm pulley position? The belt is slipping from under the 90mm pulley. I wish the SDCE set up had a wider 90mm pulley! That would make like a lot easier > but maybe you all can help to make my life easier by helping to solve my misunderstanding of this alignment issue.Align pic
Old Oct 28, 2004 | 09:32 PM
BIGBOS's Avatar
That seems pretty close, I wouldn't shim that idler
Old Oct 29, 2004 | 01:05 AM
BIGBOS's Avatar
The bracket, I have no spacer on that on mine, I do have a spacer on the blower pulley, I have the three thick spacers and one thin on each stand off, which makes for a total of 4, each setup is going to be different though
Old Oct 29, 2004 | 08:40 PM
I have to re-shim something. The last time I had it like this the belt was shreded in less than 10 miles. Anyone have pics? Advice?
Old Oct 30, 2004 | 10:03 AM
Anyone?
Old Oct 30, 2004 | 04:35 PM
Well it is all back together now. After trick o treating I'll see if it all hold together. I have my fingers crossed. The bad thing is it still doesn't look right!
Old Oct 30, 2004 | 04:40 PM
granitemonkey's Avatar
Good Luck *crosses fingers*
