blower cam
Old Nov 1, 2004 | 05:29 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
Default blower cam
whats the best sc cam that works with stock lower end?
Old Nov 1, 2004 | 05:32 AM
big one
Old Nov 1, 2004 | 05:41 AM
Inspector12's Avatar
TT-TECH Veteran
That is a matter of opinion and also depends on what your plans for the car are I use a 224/230 on a 114 it's pretty lopey and makes good power no surging or any idle problems. Stock heads I would stay in the 550-575 lift range. JMO. Good luck!
Old Nov 1, 2004 | 12:23 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How high do you want to take the engine?
I like the 224/230 stuff for a stock longblock.
Old Nov 1, 2004 | 12:42 PM
NA$TY-TA's Avatar
That is the same size cam i sujest to everyone with a stock motor.... PSJ knows that....
a 224/230 .560/.570 on a 114LSA should lope and not bleed of the boost you worked so hard to create..... YOu should be able to spin the motor to 6400 now, just make sure you op for a good set of double valve springs.....
thats my .02
Kyle
Old Nov 1, 2004 | 01:05 PM
MstgKillr's Avatar
I just used a 214/218 .540/.550 114lsa and made some good power.
