Guess what my set-up will make?
Old Nov 2, 2004 | 11:05 PM
Evil F1 SS's Avatar
How About Evil FI SS I might upgrade head unit soon! It keep changing We might see 22-25 psi so who knows???
Remember the earlyer debates on what the d1 sc and f1 were good for? It all came down to a crappy kit from procharger, not the head units themselves!
"Evil SS" was taken how is "Evil F1 SS" Gordon?
What gas are you using for the dyno session?
Old Nov 2, 2004 | 11:07 PM
Evil F1 SS's Avatar
Or put a hold on Evil F1R SS
Old Nov 2, 2004 | 11:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I was thinking Evil Gordon would be cool too.
What you upgrading your fuel pump(s)?
Old Nov 2, 2004 | 11:21 PM
Evil F1 SS's Avatar
"I rcommend going with dual Bosch pumps with the powe level the car is reaching" - Speed INC (with a sumped tank)
I would say what they think the car might make but if it doesn't I dont want it to look bad on them. We are just Guessing at this point. But for my set up it looks really good!
Old Nov 2, 2004 | 11:26 PM
LS1Tech Co-Founder
Nice.
I went wtih twin Bosch pumps and removed my Weldon pump.
Old Nov 2, 2004 | 11:28 PM
Evil F1 SS's Avatar
Nice.
What were you making at 4200 rpm?
Old Nov 2, 2004 | 11:34 PM
Z8'S's Avatar
I've seen that bracket setup somewhere before
Glad to hear its finally comin around.
Old Nov 2, 2004 | 11:35 PM
LS1Tech Co-Founder
600 @ 5000 rpms, T400, unlocked, 4300 stall.
Old Nov 2, 2004 | 11:37 PM
Evil F1 SS's Avatar
Whats the best you ride ever layed down PSJ?
I just cant wait to get some more solid #s!!!!
Old Nov 2, 2004 | 11:39 PM
LS1Tech Co-Founder
746rwhp, 6900 rpms, 17 psi, had to stop dynoing since the half and half FAST setup I was running at the time was flaking out. I will also be redynoing in the next 5-7 days and I upgraded to the YSi and made a few other changes. But you should do more you a stick shift.
Old Nov 2, 2004 | 11:42 PM
Evil F1 SS's Avatar
Has anyone made 900 rwhp with a F1 Blower on a LS1?
Im still running a small bore motor with 3 1/2 year old ARE Ls1 heads and a off the shelf single pattern cam. It seems that you dont need a super expensive big cube motor to make awsome numbers!
Old Nov 2, 2004 | 11:45 PM
  #32
LS1Tech Co-Founder
F1 record is 799/800rwhp by Bryan Wilkinson.
Old Nov 4, 2004 | 10:11 PM
  #33
Evil F1 SS's Avatar
There is a pretty decent chance the car will be on the Dyno again tomorrow! These dyno pulls are before they are going to install the GEN 7 DFI.
Old Nov 4, 2004 | 10:17 PM
  #34
BIGBOS's Avatar
I recently made 660rwhp with an F1 @ 15psi through a Th400 on slicks with a very inefficient stall....I would be well into the 700's w/a 6-speed.......
What size injectors are you running right now, I got the 60's with Speed's Twin 420 setup
Old Nov 4, 2004 | 10:20 PM
  #35
Evil F1 SS's Avatar
I think the 60s are on the car now but we are going to go with bigger injectors once the DFI is on the car!
Old Nov 4, 2004 | 10:38 PM
  #36
BIGBOS's Avatar
Yea, I wish I had the cash to go DFI, thats where the real fun begins, for now I'm gonna push the stocker as far as it will go without upgrading the 60's, the fuel system we have kicks ***
I still want to put a 3.2" pulley on it after I change the converter, that should get me close to 17psi, and probably mid 700's for rwhp
Old Nov 4, 2004 | 10:54 PM
  #37
Evil F1 SS's Avatar
Im running a 7.065 crank pulley and a 3.15 blower pulley. I was tols ill see above 20ps1!
Old Nov 4, 2004 | 11:08 PM
  #38
BIGBOS's Avatar
What kind of tensioner setup are you using.....
My crank is a 7.25" and my current blower pulley is 3.4"
Old Nov 4, 2004 | 11:18 PM
  #39
Evil F1 SS's Avatar
Its a custom 10 rib/bracket/fmic with a standard facing head unit.
Old Nov 4, 2004 | 11:20 PM
  #40
BIGBOS's Avatar
Who fabbed that up?
Also are you running an air filter on your blower?
