Boost Gauge Install
Old Nov 6, 2004 | 06:27 AM
Billiumss's Avatar
Default Boost Gauge Install
What brand and what type of boost gauges are you guys using? Electric sensor or do you run a line?
What is the best place on the drivers side to run wires and such, doesn't look like much room. Is there a useable gromment on the drivers side?
I know about the hole behind the PCM, but I have so much stuff going through there I don't think I can get anymore through it. (4ga power wire, N20 line, wire for shift light, wires for N20 system, SLP fan switch)
Old Nov 6, 2004 | 08:54 AM
dynedta's Avatar
chronic masturbator
i use an autometer mech. gauge i drilled an extra hole in the firewall used a grommet and ran line through the heater to the gauge in the vent
Old Nov 6, 2004 | 11:34 AM
DarkFormula's Avatar
Man, you should just ask me. As much as you've been around my car, I'm surprised you haven't gone through it yet
I have the Autometer Ultra-Lite mechanical. It uses a line that taps into a manifold pressure source under the hood.
There is a usable grommet on the driver's side, and that's where mine comes into the cabin.
