Help me out
Mark
Mark
NOS? I cant say much about it cause I've always been afraid of it. Dont think steet and NOS mix too well... at least not on over a 150 shot.
98-02 Camaro Z28 or Trans Am(SS and WS6 preferable) or Firehawk
I really want a BADASS Street racer car. I want something that will be VERY dependable for daily driving. Good gas mileage for the mods is a plus. A 10 Second car(without the nitrous) is the dream. MUST be a dependable daily driver though
The less miles the better.(I really don't want to get anything over 3X,XXX miles)
6 Speed is a MUST!!
T-Tops are preferable
Color is negotiable
Creature comforts(Power options, ac, heat, etc..) are a must
Good mods to have:
New engine is alright(Stokers, LS6's, etc)Keep in mind dependable daily driver
Supercharger or Turbo is real nice
heads and cam
Good rearend(Moser or Strange 12 bolt... Moser or Ford 9")
Suspension components
beautification mods are a plus
These are just preferences. I will consider any car(Except automatics). If it's the right car for the right price I will buy it.
I probably have the closest you might come to for what you are looking for but I wont be selling it cheap.
1998 Navy Blue Metallic Firebird Formula WS6, 6spd, loaded. This is a rare 1 of 2 built as it was the only 2 Navy Blue Metallic Formulas built in 1998 and can be verified.
The car is heavily modified, street driven and all OEM features and options remain functional and in excellent working order. 26,000 original miles
The engine is a bored and stroked with a custom twin turbo system
Interior
Recarro Speed racing seats grey with black inserts
Dual A Pillar pod gauge set,
Autometer boost and fuel pressure gauges
Turbo
Twin Garrett/PTE T74 GTS .85 AR housing turbos
Exhaust – Stainless steel custom headers, stainless exhaust
Intake – Dual intake, Twin intercoolers
K&N cone filters
Oil Cooler
2 independent HKS 60 mm Race Wastegates
HKS SSQV BOV 60mm
Profec B-spec electronic boost controller, mounted in console
Engine
Bored, resleveed, balanced, blueprinted 391 LS6 engine. (4.010” bore X 3.875” stroke)
Block, rods, pistons, crank, heads, valves, springs have been cryogenically treated (entire long block)
Block – LS6 4.00” bore custom tensile iron dry sleeves
Callies 4340 Forged crank 3.875” Stroke, balanced
Ross forged low compression pistons
Tapered wrist pins
Eagle 4340 I beam Rods
ARP 7/16” head and main studs
Jezel Comp R lifters
Heads - LS1 ported Stage II (305 cfm @ .500)
Manley extreme duty valves 2.05 intake 1.8 exhaust
Comp Cams 234/228/116 reverse split
Exhaust
Custom Y-Pipe
Magnaflow stainless steel catback, dual oval stainless tips
3” Mid-pipe
Manual cutout
Fuel System
Racetronix custom dual Walboro 355 intank pump,
Custom AFPR on fuel rail with braided return into tank
On the fly fuel pressure adjustable
Voltage booster and harness
Siemens 57 lb/hr flow matched injectors
Driveline Components
Blue printed T56, Upgraded synchros, Stainless 1-2/ 3-4 shift forks
B&M Ripper shifter
McLeod twin disk clutch with cintered steel flywheel
Chromemoly driveshaft
Moser 12 bolt, Eaton posi, 33 spline axles, 3.73 gears with TCS/ABS provision
Wheels and Suspension Components
Windy River stainless steel steering knuckle
Custom Chromemoly K-Frame
BMR Strut tower brace
BMR Boxed SFC’s
BMR Chromemoly tubular extreme duty crossmember
BMR Chromemoly tubular extreme duty torque arm
BMR Chromemoly tubular extreme duty panhard rod
BMR Tubular adjustable LCA’s
1LE springs
OEM Forged Z06 Titanium rims 17X9 front 18X10.5 rear
Bridgestone Potenza 275/40/ZR17 front
Bridgestone S02 295/35/ZR18 rear
Upgraded to Z06 braking system calipers and discs
They are now front mounted, the passenger turbo is in the battery location (which is now mounted in the back). For the drivers turbo I relocated the fuse box and ABS onto the frame rail which opened up the spot directly opposite the passenger turbo.
When you open the hood of the car now, there is some serious bling going on
does it still have the AC, how are you routing the downpipes?
The funny thing about the location of the turbo's where are is the frame rail already has hole that fit's perfectly, almost as if the car was built with a turbo in mind
. I did have to enlarge the drivers side hole slightly It will be interesting to see where the car works, and if lag is too big I can drop down to a 71 or 66
At least I'll give it a try
