STS on pump gas?
Old Nov 19, 2004 | 06:10 AM
Acinonyx's Avatar
Default STS on pump gas?
I've been reading through the forums on STS remote mounted turbo kits, and I have a few questions out of curiosity. What kind of boost numbers do you make on 93 octane pump gas? I don't have any experience with turbocharged larger motors such as v8's, but I've owned several imports with turbos... My last car was a 3000gt VR4 twin turbo, and I normally ran about 21 PSI of boost and got some serious performance on swapped turbos, however I had to us 110+ octane gas from VP racing, even though it was completely tuned, had an upgraded ignition system, spark timing was adjusted, etc etc. At 8 bucks a gallon here in Cali and with limited availablity it got pretty hard to boost up that high... How much can you boost before you experience knock on an STS? And what kind of 1/4 times can you get running pump gas? I saw a few guys were running 14 or so PSI of boost achieving about 640 rwhp. they just didn't specify whether they were running regular gasoline or not
Thanks for your time.
Old Nov 19, 2004 | 06:13 AM
PurEvl's Avatar
Im on pump 93 all the time, never had race gas in my car with any of my setups.
Old Nov 19, 2004 | 10:02 AM
F8L Z71's Avatar
12 Second Truck Club
You're going to need to run an intercooler if you wanna go wild with HP an try to mimic PurEvls #s.
In Cali our gas really sucks. IMO if you wanna push the envelope, get a good intercooler AND methanol. The Meth will add octane and allow you to tune more agressively. Or just do the IC and have a second tune for race gas. If you're in the Norcal area there are plenty of places that sell it, including the 2 tracks in our area.
Old Nov 19, 2004 | 10:57 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I have run up to 12 psi on pump gas with a stock 10.1:1 bottom end. It wasn't hugely efficient since I don't have a FMIC, but I did it
Old Nov 19, 2004 | 03:36 PM
z98's Avatar
z98
Boost is really a meaningless way to compare to setups, especially 2 different types of cars!
One guy on here changed his heads out and almost doubled the PSI, but made less power.
PSI really only means anything on your setup (i.e. when you turn it up).
