has anyone seen this before????
Old Nov 20, 2004 | 12:47 AM
stealthz's Avatar
Default has anyone seen this before????
I just bought a 2001 SS with a Procharger P-1SC-R1 running 6psi. It has a Moser 12 bolt rear end and 3.73 gears. Its also got a Spec-3 clutch. The car only has 85000 miles on it and I paid 12000 for it. The other day I was on my way home and got up to about a 110. After I slowed it back down I cut a donut for the hell of it and thats when the **** hit the fan. I smelt oil burning so I pulled in my driveway and popped the hood. My dipstick was sticking out about two inches and the was oil spayed out of it everywhere. I cleaned it up and went to drive it and now its cutting out. I took the procharger airbox off and there was oil on my throttle body and maf. I decided to find out where it was coming from so I followed the line coming from my passenger valve cover to the intake airbox. It was sucking oil. Theres not a PCV valve or check valve in line either. Should there be? And does this line have to run to the airbox. What can I do to lower my crankcase pressure? I took all the tubes that go to the supercharger intake and clean them of oil and also cleaned the intercoolers.
Old Nov 20, 2004 | 12:48 AM
stealthz's Avatar
Help **** has hit the fan
Old Nov 20, 2004 | 07:16 AM
DaveSchott's Avatar
LOts of info at this site try a search. This thread popped up:
https://ls1tech.com/forums/showthrea...light=dipstick
Old Nov 20, 2004 | 09:15 AM
wondermut's Avatar
Check in to evac systems or like dave said run a search. Best of luck!
Old Nov 20, 2004 | 09:43 AM
2000silverbullet's Avatar
This is pretty normal > the oil in the plastic hat on blower. I have a catch can and still oil gets by at times. I have never had my dipstick blow out, are you sure it was pushed all the way in? In your search efforts you will find a ton of pictures that should help out. Good luck.
Old Nov 20, 2004 | 10:34 AM
Rick@Synergy's Avatar
Pressurizing the crankcase can lead to very bad things. Lets just hope that's all it is..
Ohh and clean you MAF. If there is oil on it that's gonna screw with the readings and cause you to run like crap. I'd pull your plugs na ddo a compression check to be safe.
F8L Z71
Old Nov 20, 2004 | 03:45 PM
KissMySSo1's Avatar
Do a leak down test.
Old Nov 20, 2004 | 04:33 PM
goober35's Avatar
If you pcv system is working there will be oil in the line. This is just a bad dizine from GM. If it cloged then you will get that dip stick pop up like u said. Let just hope it is hook up wrong. If it is not then you are getting to much blow by in the cylenders.
 Michael S. Palmer
Old Nov 20, 2004 | 11:35 PM
BudH's Avatar
Try a 1 way checkvalve in your PCV line. The one from Mcmaster Carr in the other post is the one I use!
Old Nov 21, 2004 | 01:21 AM
got_r_done's Avatar
Yeah, put a check valve in the pcv line. It keeps the boost from pressurizing the crankcase.
Old Nov 23, 2004 | 12:11 AM
stealthz's Avatar
I did a compression test and it doesnt look good. Most of the cylinders were around 160 but three tested kinda low. #2 tested 92psi , #3 tested 44psi and #7 tested about 137. All hold pressure though. Could it still be the rings. Or could it be my valves or exhaust lobes on the camshaft? My dad just bought a lift for his shop so I'm fixing to take the motor out. this will make it alot easier. Also what would be the best way to pull the motor. Ive seen it pulled out the top but i have also seen where some people drop the hole front end suspension and all. Thanks for all the input thus far. Its helped alot.
Old Nov 23, 2004 | 12:22 AM
drozd_ws6's Avatar
Default dipstick
I had this happen to me after a drunkin 2 minute burnout. Turned out one of my pistons decided to come apart.
Old Nov 23, 2004 | 11:29 AM
IMD's Avatar
IMD
Originally Posted by goober35
dizine cylenders.
most creative spelling of the words design and cylinders, i'ver ever seen.
Old Nov 23, 2004 | 11:30 AM
IMD's Avatar
IMD
ps. yEr motEr iZ ToASt
Old Nov 24, 2004 | 07:10 PM
BlwnTA's Avatar
7 Second Club
Been there, done that, 2-pistons with broken ring lands. Good luck with your rebuild.
Mark
Old Nov 24, 2004 | 09:23 PM
Inspector12's Avatar
TT-TECH Veteran
Yep time for a forged short block. Mine took out four pistons check my sig for the photo's.
Old Nov 25, 2004 | 09:09 AM
libertine1015's Avatar
Mine was racing a S/C Saleen, 2 pistons, now Im running forged internal shortblock with low compression pistons on 10#, much happier now. Just buy a shortblock already done, $2800 put together by guys who know these motors inside and out. Many Sponsors offer one. APE, LS1Speed, ect..
Old Nov 25, 2004 | 11:26 AM
SSnakekiller's Avatar
Yep, ringlands are gone...
Check out HPE, Combination or LME
Ive only dealt with HPE and must say they know their ****
Old Nov 25, 2004 | 11:38 AM
hellbents10's Avatar
LS1Tech Sponsor
Happens all the time with factory short blocks and hyper pistons. Ring lands are gone. Well there is a upside, build a forged short block and throw more boost at it. Also make sure your tune is better cause ultimatly thats what spelled the demise of your engine.
TJ
Old Nov 25, 2004 | 06:33 PM
GrahamHill's Avatar
You might also have a broken ring, whick will lead to a land failure reeeaaal soon. Limp around, save your money, and put a couple quarts in the hatch just in case that 'low oil level' light pops up at odd times...
