Clog or 8 rib
Old Nov 26, 2004 | 02:38 PM
JESTERSS's Avatar
Question Clog or 8 rib
I am have an P1SC-1 ATI procharger with a 3.6" pulley.
I am getting sick of these belt slippage problems and I was wondering a couple of things.
I am seeing 6-7 lbs of boost at 6500 rpm.
I would like to see the 6-7 lbs of boost at 6000 rpm.
What size pulley to achieve the desired boost at this rmp?
Should I go with a clog or an 8 rib?
Where is the best place to purchase for a good price?
Thank you in advance for the advice,
Matthew
Old Nov 26, 2004 | 02:43 PM
LSs1Power's Avatar
Matthew
No need for a Cog setup. 8ribs are good for 15psi no problems. Since u have the 6 rib setup, just get the SDEC setup and that should solve your problems. Or u can always get ATI 8 rib setup + ATI superdamper. Im seeing 8psi at 6500RPM with no problems here.
I cant tell u what pulley setup to get unless i know whats your crank pulley size. What is your crank pulley size?
Old Nov 26, 2004 | 02:57 PM
JESTERSS's Avatar
Crank pulley measures 6" in diameter from edge to edge.
Old Nov 26, 2004 | 03:02 PM
LSs1Power's Avatar
So that means you are running your SC around 44416RPM at 6500RPM. If u get the ATI 8 rib which has a 7.65" crank pulley. U will need 4.10-4.15 SC pulley to get 6-7psi at 6000RPM. Im not sure what the SDEC crank pulley size is to give u the other estimate.
Old Nov 26, 2004 | 03:03 PM
badeSST's Avatar
I would get the sdce setup that's what I'll be getting, I have heard nothing but good things.
Old Nov 26, 2004 | 06:10 PM
BIGBOS's Avatar
I highly suggest the SDCE kit, I'm running one as well......15psi consistent
Old Nov 26, 2004 | 07:09 PM
IMD's Avatar
IMD
wooden shoes have been tested to provide very little performance gains.
Old Nov 26, 2004 | 07:11 PM
Got Me SOM's Avatar
yes i agree, clogs won't work.
Old Nov 26, 2004 | 07:48 PM
DarkFormula's Avatar
I'm running thw MMS crank pulley, Reichard Racing Ultra-Grip supercharger pulley, and Dayco Polycog belt.
I'm seeing 12psi and 6500 RPMs with no belt slippage, and my belt only has five ribs
Old Nov 26, 2004 | 10:40 PM
TonyJ's Avatar
Cogs work fine and are very consistent, but they're not forgiving... Make sure you've got a very strong bracket, a big-hub double-keyed dampner, and use locktite on all the bolts. Check them often, as well...
Old Nov 26, 2004 | 11:50 PM
NA$TY-TA's Avatar
Many of us have tried cogs with no luck at all...... cogs are to hard on the crankshaft itself..... Go with a SDCE spring tensioned 8 rib setup..... the crank pulley on the SDCE setup is 7.25"s.......I had the MMS crank pulley setup with a stock motor and saw 11-12 psi on a stock motor at 6200 rpm's...... you might have to call Richard racing up and have a special pulley made for you because alot of the people running a stock motor and a SDCE kit with a 4" blower pulley are seeing over 8 psi..... R Racing pulleys are about double the price of ATI pulleys though...... do a search alot of us are very happy with our SDCE setups and see the same boost every time with while ruuning the same belt for a very long time...........
Kyle
Old Nov 27, 2004 | 11:50 PM
JESTERSS's Avatar
Thank you for the help. I'll be ordering the SDCE 8 rib kit. BTW, I checked and I am running a 3.2" on the supercharger not a 3.6". Sorry about writing down the wrong size.
