Multiple misfire at idle only
I checked the compression, all cylinders are good, everything else on top of the motor also good. Again, when the car is under load everything smooths out. Anybody can help me with this?!
Bryan
Its most likley from a plug other than stock with a tighter gap. They are using probably a tr-6 or even a br7ef. Anything colder than stock will cause miss fire at idle, nothing to worry about though.
Rick
