TTI T-66 kit and fans...
Old Dec 17, 2004 | 01:07 AM
silverbullet02's Avatar
T is for Towing not Turbo
Unhappy TTI T-66 kit and fans...
So I'm in the home stretch tonight, car's been down for a while, took motor out, put ARP rod bolts and head studs in, 6.0L heads, Cam Motion cam, and a few other little things here and there since I'm doing the turbo thing...dropped in radiator, went to put fans in, and now the elbow for the turbo won't clear the fans...it's not even close. Trimming of the fan shroud isn't gonna cut it, probably gonna have to buy a new aftermarket fan here...anybody else have this problem? I was hoping to hear her spring to life tonight, but that's getting pushed off till tomorrow.
Last edited by silverbullet02; Dec 17, 2004 at 01:09 AM. Reason: Made a goof in subject line
Old Dec 17, 2004 | 06:17 AM
smokinHawk's Avatar
the stock fans wont clear with the new radiator? i used stock radiator and stock fans, id have to see pics to try and help you out.
Old Dec 17, 2004 | 10:59 AM
Stock radiator, stock fans, fans are too close to turbo and elbow won't fit.
Old Dec 17, 2004 | 11:04 AM
smokinHawk's Avatar
huh, stock fans stock radiator it wont fit, my ruber elbo was right up against the plastic fan shroud but it fit, can you get pictures so i can see if you did it right?
Old Dec 17, 2004 | 12:23 PM
RICE ETR's Avatar
Turbo Addict
Swap the rubber elbows.... put the one you got from George on the turbo and the other on the TB. Or trim down the 4" side of the 90 degree rubber elbow that is on the turbo. It was close even with trimming, but it did fit.
Old Dec 17, 2004 | 09:14 PM
Well, finally got it all figured out...a little friendly force will take care of anything
Old Dec 18, 2004 | 07:27 PM
cablebandit's Avatar
yeehaw..the BFH mod!!!
