Almost got the motor in.
Old Dec 19, 2004 | 08:51 PM
goober35's Avatar
Default Almost got the motor in.
Just need to see if i am missing something. Need to do it now before i put the motor in.
Motor
370cu
Diamond pistons -15cc
Eagle rods with ARP rod bolts
Stock crank from 6.0
228/228 .588/.588 114 lsa. Might run this with the turbo for a little while.
Main cap studs
TR oil pump
Heads studs (on the way)
PA K Member (trying to round up cash for this)
LS6 66cc heads SDPC (can we say not much back presure)
All clearances are .002-.0024 in the bearings
My rings are .020-.024
Tranny. All custom parts exsept the input and output shaft. Had a billet pump put in to handle the power.
PY3400
Is there anything that i need to get now before i drop the motor in. Other than gaskets and oil and water.
