Tuning Vortech, Green Dynojet Button?
Can anyone explain the Green Button on the Dynojet controller and the proper procedure for sampling? Is sampling the same thing as recording a run, or a calibration test?
TIA!
TIA!
Just dont press the red button by accident when you nail it also let the dyno brake slow it down and dont touch the car brakes (unless you feel the car start to roll forward). You will get used to pushing the green button and then hitting the red one quick after a few tries..
Also, when at the end of a 4th gear run, it is better to leave it in gear and use the dyno brake until lower rpms before putting in neutral, eh?
I never would use the car's brakes, but placing the car in neutral at the end of a run before dynobraking (at higher rpms) causes the PP to buzz/spin kinda fast/weird or something.
