Blower has arrived
Old Jan 6, 2005 | 11:26 AM
badeSST's Avatar
Default Blower has arrived
Well guys just wanted to let you know my blower kit is finally here. I got a box today of which was 6' 100 lbs. It was a heavy sucker, I almost had to ride it down my stairs. I got the d1sc tuner kit, as well as the sdce 8 rib setup, crank pin kit, ati damper and I do believe that's it. Now I am waiting on my mcleod clutch and the weather to clear up. I have never installed a clutch or a blower so i hope everything goes well. I also have to swap out my cam and springs but my friend has done that before. I hope everyone has a good day
Ryan.
Old Jan 6, 2005 | 01:20 PM
WS-Sick's Avatar
Nice! Have fun with everything.
Old Jan 6, 2005 | 02:29 PM
No Juice's Avatar
What cam did you pick to go with that D1
Old Jan 6, 2005 | 04:09 PM
badeSST's Avatar
fm7 224/230 .588/.593 114
Old Jan 6, 2005 | 04:18 PM
mdhmi's Avatar
Wow. Congrats. What size injectors are you using? Are you going with a FMIC?
Mark
Old Jan 6, 2005 | 04:25 PM
badeSST's Avatar
i have 60s for injectors. I will be using the twins for now, but will upgrade to fmic sometime.
Old Jan 6, 2005 | 04:33 PM
Avengeance's Avatar
Awesome! Im waiting for the last pieces of my kit then its time to install.... D1SC and SDCE tensioner kit.
FWIW I would install the clutch first, break it in, then install your blower. Reason being is you wont be able to dyno tune your blower with a fresh clutch and IMO I wouldnt install the blower until you can tune it on a dyno, but thats up to you, and if your stock clutch is toast I would want to dyno it with the new clutch instead.
Old Jan 6, 2005 | 04:37 PM
badeSST's Avatar
Avengance that is my exact plan, That is why I'm waiting until the clutch gets here. Gonna slap her on put 500 easy on her than on goes the blower. then i will start it with the stock injectors to insure everything is running smoothly. Then I will trailer it to the tuners.
