Adjusting a 50mm TIAL BOV - Got a Question?
Old Jan 12, 2005 | 11:46 AM
Arkangel77's Avatar
Default Adjusting a 50mm TIAL BOV - Got a Question?
I just set up my 50mm TIAL BOV and its leaking a tinny Bit at idol (I think?).
Hard to tell without having someone work the pedal for me BUT I think its leaking a Tinny Bit at Idol. I just wanted to Verify. To snug up the spring DO I tighten that small allen head screw that’s in the middle of the valve Under the Vac Port. If so HOW much should I turn it in? Thanks for the Help. BTW - I know it’s got be snugged if it’s leaking I just want to verify that I am doing it correctly.
Lata, Ark
Old Jan 12, 2005 | 02:06 PM
KAOS's Avatar
i have one and i didnt know it was adjustable
Old Jan 12, 2005 | 06:57 PM
Louis's Avatar
It isnt adjustable. The only way to adjust it is to take it apart and change the spring inside.
If it is open at idle, it isnt a big deal. With a cut stock spring, they hold almost 40#s with NO boost on the backside.
Old Jan 12, 2005 | 09:20 PM
Arkangel77's Avatar
Ya Lost me when you said "With a cut stock spring". IS that just the spring that they come with when you purchase them?
Thanks, Lata, Ark
