Thickest oil for turbo?
Old Jan 16, 2005 | 05:21 PM
Country Boy's Avatar
Senior Member
Default Thickest oil for turbo?
Whats the thickest oil for a turbo you can run. Reason being is I run Redline 20w50 now because my bearing clearences are a on the loose side of the scale.
Old Jan 16, 2005 | 05:30 PM
Green Thunder's Avatar
20w50 Will be fine!
Old Jan 16, 2005 | 06:44 PM
pushinfreight's Avatar
Have you got something going on that Tampa does not know about?
Old Jan 16, 2005 | 07:45 PM
Senior Member
and its going to stay that way, right
Old Jan 16, 2005 | 09:06 PM
F8LWS6's Avatar
I run 15W50 Mobil 1 Synthetic in my Turbo Trans Am. Runs excellent always high oil pressure. Best i've seen yet compared to the other weights i've used. I get around 65 - 70 psi on startup and hot it dips down to around 40.
Old Jan 16, 2005 | 09:12 PM
gator's 99TA's Avatar
i see you carl!!!!!!!!!!!!!!!!!!
Old Jan 16, 2005 | 09:17 PM
I know nothing about nothing
