Location for oil return hole in pan
Old Jan 19, 2005 | 10:46 PM
PSWired's Avatar
Default Location for oil return hole in pan
I'm currently rebuilding a 6L motor for installation into my 1995 Chevy pickup. Since I have the oil pan off and am considering adding a turbo(s) in the future I figured it would be a good idea to weld in a bung to allow for an oil return line fitting. Any suggestions for where to locate this hole (or holes) and what size to use? I realize this is a dumb, open ended question since I don't even know what type of turbo system I might use at this point, but I'm open for all suggestions. Thanks.
Old Jan 20, 2005 | 05:36 AM
tici's Avatar
Vortech wants it over the oil level so to don't have a backpressure. Size is about 1/4".
Old Jan 20, 2005 | 05:43 AM
smokinHawk's Avatar
on the side is a good place, if you have the pan off there are two ribs on the die, put it above the oil level there.
use 10an or bigger
