forced ind. question
Old Jan 26, 2005 | 08:35 PM
NY01ws6's Avatar
Default forced ind. question
i was look to do some more mods to my car before spring but all my idears are being shot down because i have the eibach sportline lowering kit its about 2in lower and now its seem like headers ypipe and crap like that ill have problems with and i dont really want to put it back to stock height unless i really have to so maybe for some quick hp i was thinking of a procharger or a turbo setup not sts though because of the ground clearance issues any any one had any problems with ground clearance and what do you recommend doing
Old Jan 26, 2005 | 08:42 PM
bud8fan's Avatar
ground clearence...hav'nt heard of anyone having ground clearence problems w/ the sts..i think your diffrential has to bottom out before the sts will...
Old Jan 26, 2005 | 08:52 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
One word... Punctuation.
If you are super low headers or the y pipe will be the lowest point on the car most of the time.
Old Jan 26, 2005 | 08:59 PM
Armageddon's Avatar
...with cheese.
Ground clearance is an issue... You'll never have to worry about the turbo bottoming out. But as far as the piping, right up around where it goes under the k-member is a big problem... also in front of the axle under the control arm. My car WAS lowered 1.5eibach. I lifted it back up real quick afterwords. If you absolutely have to stay that low, you need a turbo kit that runs its piping over the k-member. Procharger is another option to think about. Good luck
Old Jan 27, 2005 | 07:44 AM
1bad2k2ta's Avatar
LMAO LMAO LMAO LMAO
Old Jan 27, 2005 | 11:19 AM
NY01ws6's Avatar
Yeah thats what i was worried about the tubing on the turbos and the intercoolers and tubing on the superchargers i hit the stock flat pipe alot and i always scrape the air duct in the front for the rad.
